hi guys! does anyone know how to remove a cluster (speedometer)? sorry for English
(Hallo Leute! Weiß jemand, wie man einen Cluster (Tacho) entfernt? Entschuldigung für Englisch
Danke!
Danke!
Done!
1. Unscrew the bolt under the steering plastic cover
2. Remove the plastic cover on top of the steering column
3. We carefully snap off the right large decorative cover of the torpedo, not forgetting to remove the connector behind the emergency button
4. We gently snap off the left small decorative trim of the torpedo (behind the steering wheel)
5. Unscrew the 4 screws at the bottom of the agile panel (the bolts sit on the yellow plastic)
6. We take out the cluster, remembering to disconnect the connector from the back
7. The cluster can be divided by bending the latches around the perimeter.
Part number: a2c32645800
